geoff_sim
Oct 13, 2009Aspirant
USB Webcam and Motion add-on
Webcam support on the DUO Download UVC Video Drivers Download Motion Application Video drivers has been tested on arm ReadyNAS with RAIDiator 4.1.10 UVCVideo is the magic behind it all, and ...
geoff_sim
Nov 12, 2009Aspirant
Sorry, but only the cams mentioned will work :-(
Its not my work, but that of another. You can google "GSPCA" for more info. I just got it all working and packaged up on the DUO.
Once you have a camera recognised, then you can do almost anything. I am looking at getting "motion" packaged up as an add-in.
It would not be difficult to specify a capture time period, just some sort of cron job (or something like that) to start/stop the webcam app.
Sorry, no can do with the Pro as I don't have one (yet).
