geoff_sim
Oct 13, 2009Aspirant
USB Webcam and Motion add-on
Webcam support on the DUO Download UVC Video Drivers Download Motion Application Video drivers has been tested on arm ReadyNAS with RAIDiator 4.1.10 UVCVideo is the magic behind it all, and ...
J_Hutt1
Apr 14, 2011Aspirant
Working well - with one cam anyway. Couldnt quite get 2 to work (eventho each cam works separately on its own)
Tried creating a thread1.conf and thread2.conf from the motion.conf file...with separate settings, and placing in the /media/motion directory along with the original motion.conf, restarting...but it stopped either cam from working. Any tips?
Also
Is it possible to use a single url to start motion up & shut it down from a browser without having to go into Frontview?. Like the following which works for Transmission;
ON: <NAS IP>/TRANSMISSION/TRANSMISSION_HANDLER.pl?command=ToggleService&OPERATION=set&CHECKBOX_TRANSMISSION_ENABLED=unchecked
OFF: <NAS IP>/TRANSMISSION/TRANSMISSION_HANDLER.pl?command=ToggleService&OPERATION=set&CHECKBOX_TRANSMISSION_ENABLED=unchecked
Also
