geoff_sim
Oct 13, 2009Aspirant
USB Webcam and Motion add-on
Webcam support on the DUO Download UVC Video Drivers Download Motion Application Video drivers has been tested on arm ReadyNAS with RAIDiator 4.1.10 UVCVideo is the magic behind it all, and ...
geoff_sim
Oct 09, 2012Aspirant
I've just checked that they still work with the latest ReadNAS build, 4.1.10.
Install the UVC drivers 1st, then Motion.
When you look at Motion in the installed add-ons, refresh the screen if you don't see the default folder locations.
A few other things:
1. Motion will start immediately you install it.
2. The default motion.conf supplied will start a video capture.
You may want to change this (comment out ffmpeg_cap_new entry or set it to no and start/stop motion).
3. When you move the motion folder to another location, the old location contents are not deleted.
Motion is quite flexible, so you should be able to do what you want with it. I was going to add a scheduler, but there was little interest.
Enjoy.
A few other things:
Enjoy.
