shaggys
Jan 28, 2010Aspirant
WAKE addon problem
Hi Just installed the WAKE addon but when trying to wake a computer upp I get the error below. Do I have the wrong PHP version on my DUO? I use PHP from here PHP5 5.2.11 from WhoCares http://ww...
gonzo_74
Feb 06, 2010Aspirant
I was able to get the Wake feature to work by replacing a section of Super-Poussin's code.
For setting a broadcast option to socket, this is what I did:
// $opt_ret = socket_set_option($s, 1, 6, TRUE);
if(socket_sendto($s, $msg, strlen($msg), 0, $addr, $socket_number)) {
echo "Magic Packet sent successfully!";
socket_close($s);
return TRUE;
else {
echo "Magic packet failed!";
return FALSE;
That 1st line is from Super-Poussin's code, and I disabled the line and then replaced the code from that line through the line that said "your PC with Mac Address xx-xx-xx-xx-xx has been awakened!"
I am able to do a Wake On Lan through my website now. I'm not sure why I can do it, but I can. It seems that the socket set option is optional. I am only trying to wake 1 computer, so maybe there is something to do with that.
Hope that helps.
socket_close($s);
return TRUE;
else {
return FALSE;
Hope that helps.
