shaggys
Jan 28, 2010Aspirant
WAKE addon problem
Hi Just installed the WAKE addon but when trying to wake a computer upp I get the error below. Do I have the wrong PHP version on my DUO? I use PHP from here PHP5 5.2.11 from WhoCares http://ww...
mtjoernelund
Feb 07, 2010Aspirant
gonzo_74 wrote:
// $opt_ret = socket_set_option($s, 1, 6, TRUE);
I do not think you need to disable the above line. Just replace it with this:
$opt_ret = socket_set_option($s, SOL_SOCKET, SO_BROADCAST, TRUE);
And then it should work. (BTW, am using php5 on my readynas duo).
