shaggys
Jan 28, 2010Aspirant
WAKE addon problem
Hi Just installed the WAKE addon but when trying to wake a computer upp I get the error below. Do I have the wrong PHP version on my DUO? I use PHP from here PHP5 5.2.11 from WhoCares http://ww...
Joris1
Feb 11, 2010Aspirant
mtjoernelund wrote: I do not think you need to disable the above line. Just replace it with this:
gonzo_74 wrote:
// $opt_ret = socket_set_option($s, 1, 6, TRUE);
$opt_ret = socket_set_option($s, SOL_SOCKET, SO_BROADCAST, TRUE);
No more problems here after I replaced the line above and changed the value of $ip_addy in action.php to the correct value for my LAN. Thanks mtjoernelund & super-poussin!
