dmahon1
Nov 26, 2011Aspirant
What exactly does it offer?
I have a ReadyNAS (NVX). It has an IP address. I backup daily to an external device and use ReadyNAS Vault for my most important items so they are backed up almost instantly and have versions availabl...
Feb 12, 2012Guru - Experienced User
I don't understand your problem. If you are only using one device at a time, and you are storing things on the NAS, then why is there a need to manually sync anything?
