SeaMUNKY
Aug 07, 2020Aspirant
Where to download addons for ReadyNAS Duo V1 (sparc)?
Hello all Turining to your expert help to see if anyone can guide find a repository or share old addons links. I have tried most sources including rnxtras.com but failed to collect few addons for m...
Aug 07, 2020Guru - Experienced User
rnxtras.com does have some of these here: https://rnxtras.com/readynas-os4-sparc Though he does charge a small amount, he also provides support.
The KB page points to the old ReadyNAS forum - which was decommisioned a long time ago. JohnCM_S , Marc_V : it should be taken down. Many of the old posts in this area were transfered over from the old forum - some have links that no longer work (stuff like viewtopic.php?f=47&t=21791 )
You can use wayback to access the old forum here: https://web.archive.org/web/20111121174352/http://www.readynas.com/forum/viewforum.php?f=47
Some of the binaries can be downloaded that way, but of course some of the links might be dead.
SeaMUNKY wrote:I have tried most sources including rnxtras.com but failed to collect few addons for my Model: ReadyNASRND2000
General advice here - the Duo has very limited resources - a sparc processor designed back in 2005, stock memory of 256 mb, and a linux OS partition of only 2 GB. The version of linux it runs is ancient, and it cannot be upgraded. Loading it up with lot of add-ons isn't a good idea - you will end up filling the OS partition, which will give you a NAS that won't boot. And even just one or two won't give very good performance by modern standards.
A better strategy would be to spin up a modern linux system - perhaps on an old PC or in a VM - or alternatively in a raspberry pi. You can mount the NAS volume as a network share on the linux PC, and run whatever linux applications you like. You can also just do this on a windows PC or a mac, and run applications like plex on them.
- SandsharkAug 07, 2020Sensei
There are some here: RAIDiator-Third-Party-Add-ons. Just select ones that are for the SPARC architecture.
- SeaMUNKYAug 07, 2020Aspirant
Sandshark when clicked on "sparc" for respective addons, it redirects to this page - https://www.netgear.com/business/products/storage/readynas/
I already mentioed in my main post
Sandsharkfor instance when clicked on [https://www.readynas.com/forum/viewtopic.php?f=47&t=41666] it re-directs to https://www.netgear.com/business/products/storage/readynas/
