doof205
Mar 14, 2011Aspirant
xbox 360 streaming with twonky
Hi, my first post here after picking up a ReadyNas Duo. I spent ages last night trying to get media streaming working from my ReadyNas Duo to my Xbox 360. Finally, after about 4 hours googling etc it ...
pucheteca
Dec 12, 2011Aspirant
i had exactly the same problem, the xbox took a while to show the twonky server on the source list. i recently changed my router and magicly its working like a charm appears as first in the source list and really fast! try using another router or even a wired direct conenction to see if the problem goes if so then you know what you have to change!
