jz11
Mar 03, 2012Aspirant
ZNC IRC Bouncer for ReadyNAS DUO (Sparc)
Would be great to have a bouncer available for the readynas. As far as i know there isnt one yet. Thanks
mfe_
Mar 07, 2012Tutor
Because I haven't dealt with making addons yet, I can only tell you how to compile that stuff.
I upgraded my compiling enviroment but I hope you can compile this with the standard readynas duo enviroment.
First enable ssh access with the addon.
Download the src
Change to an temporary directory like media and download src
extract it
build pkgconfig
build znc
I didnt test the input because of the diffrent readynas enviroment.
Because of library dependencies you might need to install the required lib. If problems occour tell me. I'll try to help.
Download the src
cd /media/
wget http://pkgconfig.freedesktop.org/releases/pkgconfig-0.16.0.tar.gz
wget http://pkgs.fedoraproject.org/repo/pkgs/znc/znc-0.202.tar.gz/3c6ff4620e139e3d9745cd53111bab20/znc-0.202.tar.gz
extract it
tar xvfz pkgconfig-0.16.0.tar.gz
tar xvfz znc-0.202.tar.gz
build pkgconfig
cd pkgconfig-0.16.0
./configure --build='sparc-linux'
make
#if compiling was successful install it
make install
build znc
cd ..
cd znc-0.202
./configure --host='sparc-linux' --enable-debug --prefix=/c/apps/
make
make install
