tiranor2's avatar
tiranor2
100Mbit capped network speed
Hi there,
A few months ago i was close to losing my ultra 4 with os 4 due to corruption in my os partition.
As debian etch is really old, and seeing that os6 works well with those older units, i replaced my ultra 4 with a more powerful unit (acer ac100 bought really cheap, with xeon e3 quad core cpu).
since then, i've upgraded my ultra 4 to os 6.10.2, with the goal of having an up to date backup nas.
as i've recently bought newer hdds, i finally got enough space to do a full backup. But this is where things get wrong :
- with rsync i get 10-11MB transfer when pushing from my server
- same with ftp, both with upload or download
- same with iperf (95Mb)
- thinking it was my nas that got slow, i tried locally with dd, but it saturates my hdd (140+ MBytes for single disk) in reading or writing.
- with os4, with ftp, my speed was around 800-900mb read and 400-500mb write
As the speed is too close to fast ethernet speed, i suspected an error of the negociation, but my prosafe switch reports gigabit ethernet too.
Suspecting a faulty nic, i used the second one, with the same results...
Several rebooting (including the 6.10.3 update) didn't solve anything either.
Network isn't faulty, i changed the cables, even connecting without the switch, without result.
Any idea ? (before considering the dilemma between going back to os4 or accepting having only 100mb capped speed)
  • What speed (i.e. "bandwidth") are you seeing on the network tab of the NAS admin UI?
    Have you tested the SMB speed?   For instance, using NASTester on a windows PC?  http://www.808.dk/?code-csharp-nas-performance
    Maybe also download the full log zip and look at the ethernet stats (network_settings.log).
  • StephenB's avatar
    • tiranor2's avatar
      tiranor2
      Thanks for the reply, i finally tested with my windows computer, and i get 110MB/s CIFS/SMB read speed and 90-95MB/s write speed.
      I then tested with my server, and somewhat, my server has switched to fast ethernet, without me knowing.
      I'll have to troubleshoot it, but my Readynas finally works better than ever (i never had such transfer speed over SMB).
      Thanks again for the pointers.
ProSupport for Business
