Retired_Member
Dec 20, 20121080p streaming ?
I have a ReadyNAS (the gray one with 4 HDD but not the Ultra version). I'm using it to put my 1080p movies and then i play them from my TV. However, i have noticed a small lag when things are mo...
TeknoJnky
Dec 20, 2012Hero
more likely its the client.
have you tried streaming the same movie from the ultra?
most single hd streams generally can be streamed on fast ethernet (ie appletv), unless you are doing some other heavy io while streaming, even the old sparc devices can stream hd.
