Retired_Member
Dec 20, 20121080p streaming ?
I have a ReadyNAS (the gray one with 4 HDD but not the Ultra version). I'm using it to put my 1080p movies and then i play them from my TV. However, i have noticed a small lag when things are mo...
Dec 20, 2012Guru - Experienced User
Ok.
anarchoi wrote: Ok i guess it answer my question then. I thought maybe ReadyNAS didn't have enough bandwidth for full HD streaming.
What i mean by lag is that the frame rate appears to slow down during big action scenes. Sometimes it freezes for a fraction of second then start again
Causes for this kind of thing can be (1) the media file itself has a problem, (2) the playback capacity of the player (GPU performance or insufficient buffering), (3) a network issue of some kind, (4) the server.
You can try copying the file over to the ultra and also the HTPC local disk, and see if the problem changes.
