dahaun
Feb 27, 2013Aspirant
10GbE Ethernet Cards
Good Morning: Readynas 3200.. Has anyone had any luck putting a 10gb Ethernet Card in this unit.... Thanks, Darren
chirpa
Feb 27, 2013Luminary
Probably won't work. I believe there was code in the system, if the model wasn't sold with 10Gbe, or a 'supported' model, it would ignore cards placed in there afterwards.
Can you download the System Logs (FrontView>Status>Logs>Download All Logs), then open up boot_info.log in the zip file. Tell me what the '10gige' line says, 0 or 1. If it's 0, the system won't take a 10GbE NIC, even if it has a slot for it.
There are hacks to get it working though, I'd have to experiment. Basically it unbinds the drivers on boot up.
