dahaun
Feb 27, 2013Aspirant
10GbE Ethernet Cards
Good Morning: Readynas 3200.. Has anyone had any luck putting a 10gb Ethernet Card in this unit.... Thanks, Darren
mdgm-ntgr
Feb 27, 2013NETGEAR Employee Retired
The log chirpa meant to refer to was boot_info.log. You should have that log file in the zip file you downloaded.
The dual gig E card would definitely work in the 3200.
