betty23
Sep 01, 2013Aspirant
10TB with USB expansion on Duo V1 possible?
Hi forum members, Based on my searching, it seems to me that the following is possible on a Duo v1 (sparc) but I want to be sure before I expand: I have 2X2tb As raid 0 = 4Tb. The duo has 3 usb...
vandermerwe
Sep 01, 2013Master
Possible yes.
Performace is probably going to be less than satisfactory unless you're just using the USB drives for data hat you don't access a lot. I think if you are accessing the usb drives a lot this may be a problem, although I don't have exact read/ wite performance data.
Data wil be at risk unless you have everything backed up somewhere else.
It sounds like you need a larger NAS.
