betty23
Sep 01, 2013Aspirant
10TB with USB expansion on Duo V1 possible?
Hi forum members, Based on my searching, it seems to me that the following is possible on a Duo v1 (sparc) but I want to be sure before I expand: I have 2X2tb As raid 0 = 4Tb. The duo has 3 usb...
Sep 02, 2013Guru - Experienced User
You will either need to clone the failing drive (with the NAS off) or destroy the existing volume. Replacing the drive w/o that requires xraid or raid-1.
If you do destroy the volume, I would definitely go with a two-volume approach (one for each drive).
