betty23
Sep 01, 2013Aspirant
10TB with USB expansion on Duo V1 possible?
Hi forum members, Based on my searching, it seems to me that the following is possible on a Duo v1 (sparc) but I want to be sure before I expand: I have 2X2tb As raid 0 = 4Tb. The duo has 3 usb...
betty23
Sep 03, 2013Aspirant
Will definitely do the two volume approach. Thanks for the advice. As I understand it, I run through the following procedure:
1. Back up files from current drive to an external drive connected to my pc.
2. Add new drive 1 to bay 1 and set up raid 0.
3. Shut down readynas
4. Add new drive 2 to bay 2 and boot up readynas
5. go to add volumes and create as raid0.
Correct?
Thanks again!
betty
Correct?
Thanks again!
betty
