betty23
Sep 01, 2013Aspirant
10TB with USB expansion on Duo V1 possible?
Hi forum members, Based on my searching, it seems to me that the following is possible on a Duo v1 (sparc) but I want to be sure before I expand: I have 2X2tb As raid 0 = 4Tb. The duo has 3 usb...
Sep 03, 2013Guru - Experienced User
Basically yes. My music library grows slowly, my video library grows more quickly,... Since rebalancing the storage requires moving shares between the volumes, it is a mild nuisance. So I try not to put all the rapidly growing shares on the same volume, because I don't want to do it very often.
betty23 wrote: When you say "growth rates," you mean the rate at which I am adding data to each drive, correct? That should be too tough to manage...
Don't over-think it, it's just a suggestion that you spend a couple minutes working out what shares you place on what volumes.
