vrspectre's avatar
vrspectre
Apprentice
May 24, 2017
2 resyncs after drive upgraded
I've got a 516 that loaded with 4TB drives. I've been replacing them with 6TB drives for a while now. I'm setup with RAID 6.    The process i use is to pull out the 4TB drive, and put the 6TB drive...
  • StephenB's avatar
    May 25, 2017
    The NAS preserves the original 6x1TB raid layer, and adds a new 3TB layer on top (currently 5x3TB). Both layers needed to be synced, so there are two phases.
    Since RAID-6 requires the four largest drives to be the same size, you should have seen expansion from 4 TB to 10 TB when you added upgraded the 4th drive. The NAS likely needed to be rebooted at that point.
ProSupport for Business
