pyby
Jan 11, 2017Aspirant
2120 - after freeze and reboot all volumes are lost
I've got huge problem with netgear - after a freeze i made a reboot. Then there are no volumes, all data is inaccessible. Screenshot below. Could you please tell me how to restore my data? it's...
pyby
Can i reboot using backend web panel or I need to do it manually by pressing power off/on?
mdgm-ntgr
Jan 11, 2017NETGEAR Employee Retired
Either.
- mdgm-ntgrJan 11, 2017NETGEAR Employee Retired
You should contact support.
- pybyJan 11, 2017Aspirant
Thank you. There's no option to boot nas in read only mode? the data won't be visible?
- StephenBJan 11, 2017Guru - Experienced User
There is, but that only helps if the volume(s) can be mounted. So it won't be useful.
Support can isolate it more quickly, though there is some likelihood that you will need a data recovery contract to get the data back. Is the data backed up?
- Jan 17, 2024Retired_Member
