alaeth
Jul 12, 2017Aspirant
Missing volume after hard reboot
After losing access (no web, ssh, mounts, anything) from my ReadyNAS Pro 6 running 6.7.4 firmware, I decided to hard-reboot it by holding down the power button until it powered off. after booting back up, I was confronted by no data and two volumes (zero bytes each).
A quick search turned up this post:
https://community.netgear.com/t5/Using-your-ReadyNAS/Missing-volume-after-power-failure/td-p/1246361
However the troubleshooting steps in it do not match my experience (my /mnt/data/ is empty)...
Any help would be greatly appreciated.
I've uploaded the logs from today here:
https://drive.google.com/drive/folders/0BwD0UWci-5MxOU5Sc0lNS3IzWWM?usp=sharing
I'm going to consider the data lost, and rebuild/factory reset back down to 4.2 for stability.
I think this is the answer without getting into costly data recovery services, or massive time investment.
It looks like there's some file corruption. Per Kernel.log
Jul 12 20:27:09 readynas01 kernel: BTRFS: device label 33ea999f:data devid 1 transid 1431232 /dev/md127
Jul 12 20:27:09 readynas01 kernel: BTRFS info (device md127): has skinny extents
Jul 12 20:27:10 readynas01 kernel: BTRFS critical (device md127): corrupt leaf, slot offset bad: block=2291416563712, root=1, slot=77
Jul 12 20:27:10 readynas01 kernel: BTRFS error (device md127): failed to read block groups: -5
Jul 12 20:27:10 readynas01 kernel: BTRFS error (device md127): failed to read block groups: -5Jul 12 20:27:10 readynas01 kernel: BTRFS error (device md127): open_ctree failed
jak0lantash might have some suggestions on next steps.
- alaethAspirant
That seems... not good. :(
I bought a QNAP and am trying to get data restored manually for now. Luckily I have online backups of the critical stuff (10+ years of photography shoots and proofs).
Regardless of the outcome, I think I'll roll-back the firmware to the "officially" supported version 4.x. Ever since upgrading to the unsupported 6.x, I've noticed it locks up fairly often - I even setup a cron job to reboot it nightly to try and reduce the impact.
I know any OS dis-likes hard-reset... and it's been restarted this way a few times in the past couple months.
My wife thinks it's because she gave it the middle finger before powering it off...
- jak0lantashMentor
I'm taking a look at the logs now. But you should remove them for Google Drive. There is your serial number in there.
