john_es
Mar 16, 2015Aspirant
316: Jumbo Frames
I am gettin gsuper slow copies from my Windows 7 machien to my 316. Win 7: 1Gbps wired cat6 ethernet, MTU = 1500, adapter set for jumbo frame support. Netgear switch that allows for jumbo frames ...
Mar 16, 2015Guru - Experienced User
First of all, you enable jumbo frames by setting the MTU above 1500. But I'd recommend setting the MTU on the Win7 to 1500 next (instead of enabling JF on the NAS).
Ixa's suggestion to try a direct connect is reasonable - we often suggest this to rule out the switch (and cabling) as the cause of the problem.
