alokeprasad's avatar
Dec 15, 2018
Jumbo frame MTU size in Duo v1?
Hi,
I'm trying to maximize the network speeds between 3 devices (PC, Duo_v1, Qnap NAS) connected to a Netgear GS108_v3 by matching the MTU size in their ethernet interface settings.
The MTU sizes supported by these devices are:
   GS108_ver 3: up to 9,720 bytes
   The PC: disabled (1500 i guess), 4088, 9014
   Qnap: 1500, 4074, 7418, and 9000 bytes
   Duo_ver1 running RAIDator 4.1.16:    ??
What MTU values are supported by the Duo if I enable Jumbo Frames on it?
Thanks.
Aloke
  • PS: Frontview on the Duo is showing
       Speed/Duplex mode: Auto-negotiated
       MTU:7936 bytes (greyed out).
       Jumbo Frames is enabled on the Duo.
    So, these numbers are all over the place.
    7936 (Duo),
    1500, 4088, 9014 (PC Intel(R) Ethernet Connection (2) I218-V),
    1500, 4074, 7418, and 9000 (Qnap)
    GS108 is autonegotiated.
    What value should I set these at?
    • alokeprasad's avatar
      alokeprasad
      Mentor
      I'm getting transfer rate of 94.5 MB/s for large video files (.m2ts) on a 1 GB/s link.
      This is from the PC to the Qnap.
      That's pretty good!  Can I expect to do any better?
      I might just leave things alone....
ProSupport for Business
