gparkerCOB's avatar
gparkerCOB
how to enable Jumbo Frames on XS748T? Can't find the setting.
I have searched and found a article on the site showing how to enable Jumbo Frames on Pro Safe switches, but the interface in the XS748T looks different than their example and I can't find where to enable Jumbo Frames on the XS748T.
Anyone know how?
Thanks!
  • Carl_z's avatar
    Carl_z
    Jun 27, 2018
    Hi gparkerCOB
    Sorry for late to back, I missed your reply.
    For XS748T Jumbo Frames is enabled by default. You can just use Jumbo Frames without any configurations.
    BestRegards
    Carl
  • Carl_z's avatar
    Carl_z
    NETGEAR Expert
    Hi gparkerCOB,
    Welcome to the community!
     You can go to "Switching/Ports/Port Configuration/"  There is a value named "Maximum
    Frame Size". Just set this value to max to enable Jumbo Frames.
    Best Regards
    Carl
    Netgear Employee
    • gparkerCOB's avatar
      gparkerCOB
      Thanks Carl! I wish ours looked that way. The image you attached is much like the knowlagebase had seen while sreaching for the answer. But our switch does not have that value to change. Is it because all the ports on the switch are 10GbE? See the image below.
      gparkerCOB
      Carl,
      Any ideas why our switch doesn't have that setting you talked about?
      Thanks
      • Carl_z's avatar
        Carl_z
        NETGEAR Expert
        Hi gparkerCOB
        BestRegards
        Carl
ProSupport for Business
