alokeprasad
Dec 15, 2018Mentor
Jumbo frame MTU size in Duo v1?
Hi,
I'm trying to maximize the network speeds between 3 devices (PC, Duo_v1, Qnap NAS) connected to a Netgear GS108_v3 by matching the MTU size in their ethernet interface settings.
The MTU s...
- Dec 16, 2018
9000 works.
alokeprasad
Dec 15, 2018Mentor
PS: Frontview on the Duo is showing
Speed/Duplex mode: Auto-negotiated
MTU:7936 bytes (greyed out).
Jumbo Frames is enabled on the Duo.
So, these numbers are all over the place.
7936 (Duo),
1500, 4088, 9014 (PC Intel(R) Ethernet Connection (2) I218-V),
1500, 4074, 7418, and 9000 (Qnap)
GS108 is autonegotiated.
What value should I set these at?
