radioguru6613
Sep 02, 2015Aspirant
3220 Horizontal Upgrade Planned
Just wanted to make sure I'm reading the manual correctly. We launced a 3220 box wtih 8 out of 12 drives populated, each drive is a 4TB red and the box has had some traffic with minor file loading and 1 LUN for a domain backup.
We're going to migrate the box to 12 drives but if I'm reading the manual correctly our Raid-6 configuration will need to be migrated to an X-Raid config before we can add drives... correct?
Is there an actual procedure doc that outlines the correct way to add drives? Power on, Power Off? Raid-6 to X-Raid before or after... looking for guideance.
3220 is at release 6.2.4 (Current release)
Thanks,
Miguel
The manual does say that you need to switch to xraid in order to expand horizontally. That is easy to do, and with OS 6 it is non-destructive. Your data will remain intact, and you will still have dual redundancy. (If for some reason you do see a warning, and are asked to type "DESTROY", then certainly stop!)
Though I am a huge fan of the WD Red drives, I'd be a bit worried about vibration with 12 in the chassis. You might want to add WDC Red Pros (which are spec'd for 16 bay NAS, and are enterprise class). I'd leave the existing Reds, but would likely replace any failed drives in the future with the Pro.
Just a thought...
- radioguru6613Aspirant
Thanks Stephen,
Actually the new 4 are PRO Series drives (WD4001FFSX) to be exact but you answered my #1 question, I won't loose the volume. It's not a production machine .. YET .. however after a couple of weeks of testing it's finding it's place to replace the Synoogy units that were in the rack before it.
I wasn't confident in a propriertary raid format (X-Raid) so I opted to launch with the more establisted Raid-6 however I didn't read far enough in to see the discaimer about the need to be in X-Raid to expand the system.
The button has been pushed, not it's just a matter of time for the system to become X-Raid.
Thanks again.
- mdgm-ntgrNETGEAR Employee Retired
X-RAID2 uses standard RAID levels. The automation of expansion is what makes X-RAID2 special.
