IanSav
Nov 30, 2010Apprentice
4.1.7 Slow To Respond To SMB Network Discovery...
Hi, Since upgrading my DUO to 4.1.7 I have noticed that the DUO is *very* slow to respond SMB/SAMBA network share enumeration requests. It may take up to about a minute for the DUO to provide its ...
siigna
Jul 15, 2011NETGEAR Employee Retired
Hey guys,
I've got a bug open with the dev team, but can you guys that are experiencing this issue still try a few things here?
Firstly try the SMBNoDisconnect add-on and see if this makes a difference:
http://www.readynas.com/download/addons ... ct_0.2.bin
Another thing you may want to try are these registry tweaks:
[Start] [Run] [Regedit]
Registry Key: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\RemoteComputer\NameSpace
Modify/Create the Value Data Type(s) and Value Name(s) as detailed below.
Disable Scheduled Task Checking
Value Name: {D6277990-4C6A-11CF-8D87-00AA0060F5BF}
Delete the sub-key in the left pane of Registry Editor
Disable Printer Checking
Value Name: {2227A280-3AEA-1069-A2DE-08002B30309D}
Exit Registry and Reboot
