Haree2010
Dec 11, 2024Tutor
Bonjour device discovery issue
Hi, I have recently replace an old L2/L3 switch with Netgear GS752TPV3. Bonjour devices such as printers and other devices fails to be discovered by some computers. It used to work fine on the old switch. I couldn't find any mDNS settings on this switch. Any help would be greatly appreciated.
TIA
Haree2010 wrote:
Firmware Version V6.1.0.10
Current firmware is v6.2.0.36, so time for an update is long overdue.
Firmware version?
Using the default VLAN and config?
Hi Renna,
Thank you for your reply. It's good to hear that there was a fix in the latest firmware. I did not update the firmware as the switch also developed an issue with the port LEDs. Netgear agreed to send a replacement. I will check and update the firmware on the new switch and will post the results here.
Thanks!
- RennaDNETGEAR Moderator
Hi Haree2010,
Once you received the replacement switch, go ahead and update it to the latest using the link below:
https://kb.netgear.com/000066329/GS728TPv3-GS728TPPv3-GS752TPv3-GS752TPPv3-Firmware-version-6-2-0-36
Have a lovely day,
RennaD
Netgear TeamHi guys, updating to the latest firmware fixed the issue on both old and new switch. Port LEDs are working fine on the new switch. However now the replacement switch I have received is already registered on someone else's account.
