Haree2010
Dec 11, 2024Tutor
Bonjour device discovery issue
Hi, I have recently replace an old L2/L3 switch with Netgear GS752TPV3. Bonjour devices such as printers and other devices fails to be discovered by some computers. It used to work fine on the old sw...
RennaD
Dec 17, 2024NETGEAR Moderator
Hi Haree2010,
Welcome to the NETGEAR Community! 🙂
There was indeed a fix related to multicast control packets on firmware version 6.2.0.24.
Were you able to update to the latest version 6.2.0.36 and did it help with the issue you reported?
Have a lovely day,
RennaD
Netgear Team
- Haree2010Dec 18, 2024Tutor
Hi Renna,
Thank you for your reply. It's good to hear that there was a fix in the latest firmware. I did not update the firmware as the switch also developed an issue with the port LEDs. Netgear agreed to send a replacement. I will check and update the firmware on the new switch and will post the results here.
Thanks!
- RennaDDec 18, 2024NETGEAR Moderator
Hi Haree2010,
Once you received the replacement switch, go ahead and update it to the latest using the link below:
https://kb.netgear.com/000066329/GS728TPv3-GS728TPPv3-GS752TPv3-GS752TPPv3-Firmware-version-6-2-0-36
Have a lovely day,
RennaD
Netgear Team- Haree2010Dec 20, 2024Tutor
Hi guys, updating to the latest firmware fixed the issue on both old and new switch. Port LEDs are working fine on the new switch. However now the replacement switch I have received is already registered on someone else's account.
- schumakuDec 20, 2024Guru - Experienced User
The warranty replacements you receive from Netgear are already registered to -your- account (and with the same warranty and support time endorsements as the one replaced).
