IanSav
Nov 30, 2010Apprentice
4.1.7 Slow To Respond To SMB Network Discovery...
Hi,
Since upgrading my DUO to 4.1.7 I have noticed that the DUO is *very* slow to respond SMB/SAMBA network share enumeration requests. It may take up to about a minute for the DUO to provide its list of shares. The problem happens *every* time the DUO is asked to list its shares and not just for the first request. This was not an issue under 4.1.6. (I never ran any of the betas and upgraded from 4.1.6 production directly to 4.1.7 production. There were no obvious issues with the upgrade.)
On a client PC this results in about a minute of waiting before the DUO responds with a share list. This is long but not particularly problematic. On the other hand, to my media players this response is *so* long that the media player times out and is no longer able to find the DUO. This is *very* problematic.
This is only happening on my DUO with 4.1.7. The same DUO with 4.1.6 was fine and my NVX with 4.2.15 is also fine.
Is it possible to get a patch to repair this issue? Is there anything I can do to restore the previously snappy performance? Is it safe/possible to revert to 4.1.6?
Ian.
Ian.
- WSJTutor
Jedi Knight wrote: The only thing I can think of is was somehow samba daemon become unresponsive after reboot (or) doesn't get started correctly (however, if you restart the services by manually, it works fine).
Any news / updates on the topic?
It seems that many ReadyNAS customers are facing those performance issues after applying the new firmware.
O.k - now it's christmas time. But the issue has been reported quite a while before the winter break.
I'd like to know if someone is already / still working on the issue. Is the root cause analysis completed?
Are you already working on a patch? - NyarlathotepAspirant+1 for the disable/re-enable "trick." I bought my ReadyNAS Duo recently and never used any firmware other than 4.1.7, so I have no idea how the speed "should" have been, but I did notice that it was slow. After disabling and re-enabling CIFS, network discovery is much faster, even over an OpenVPN connection through a tethered cell phone (I'm currently on a train).
- IanSavApprenticeHi Jedi Knight,
Following on from your request above, and your PMs to me, I made some time to perform an OS Reinstall. I regret to inform you that this has made *no* difference to this problem.
The stop/start of the CIFS service has once again saved the day and restored the NAS to a working state.
Ian. - WSJTutorSee also the posting of "Nyarlathotep":
He has bought a new ReadyNAS Duo with firmware 4.1.7 - facing the same issues. So, it's not a matter of upgrades. The firmware version 4.1.7 is buggy - and hopefully there'll be soon a bugfix.
@Ian: Thank you for that information - so, it's not worth to perform an OS reinstall. - IanSavApprenticeHi WSJ,
WSJ wrote: @Ian: Thank you for that information - so, it's not worth to perform an OS reinstall.
If it isn't too disruptive you may care to try the reinstall yourself to confirm my observation. All this broke was the admin password and the NAS digital certificate. Both were easily fixed.
Ian. - arsenicrunAspirantGood news, Everyone!
I finally had the opportunity to back up the data on one of my ReadyNAS Duos. Feeling a bit more secure having taken that precaution, I searched for information about downgrading to 4.1.6. Here's what I found out :)
The page announcing the release of 4.1.6 on July 15, 2009 is still alive! And it can be found at http://www.readynas.com/?p=2620
On that page, you'll find the image for the 4.1.6 firmware still being served in its original form at http://www.readynas.com/download/RAIDiator/RAIDiator-4.1.6 (this is a direct link to the 59.4 MB image which you can use to do a "Local Update" in your ReadyNAS web config screens).
When you click "Upload and verify image..." it will think for a few moments and then results in this screen
Happily, I clicked Perform System Update. The ReadyNAS Duo immediately told me to reboot. It took a few minutes to update itself while booting, but after that I am pleased to report that all of my settings, shares and files were intact. Browsing to the CIFS share was instant without using the toggling hack. I rebooted and browsed to my share just to confirm, and yes, the discovery is instant again.
Purely in the interest of science, I rebooted my ReadyNAS Duo that still has 4.1.7 on it. It took the ~30 seconds to find the CIFS share, as usual. I will be downgrading this one as well after posting this reply.
tl;dr - I have confirmed that downgrading to 4.1.6 fixes this bug.
I hope this helps,
Sean
PS - I must admit that I had hoped for the Netgear crew to help me out on these forums instead of having to figure this stuff out myself. In the future it'd be nice to have more acknowledgment, concern and updates about the progress towards fixing bugs like this one. - Quinten1AspirantOut of interest, could you do a
smbd --version
on both your Duo's ? - NyarlathotepAspirant
Unfortunately, that is not an option for me, as I need 4.1.7 for my WD EARS drives (the same ones as "Quentin") with 4K sectors... I'll have to wait until the next release. - arsenicrunAspirant
Quinten wrote: Out of interest, could you do a smbd --version
I have like, zero experience doing command-line stuff with network devices. Let me know how to do this and I'll post the result when I get home from work today.
Happy New Year! - Quinten1AspirantYou have to install the Enable Root SSH Access (http://www.readynas.com/?p=4203) plugin (if you haven't done this yet) and then log in using Putty or another terminal emulator. Once in, just type the command above.
