DeltaTee
Jul 22, 2011Aspirant
[4.1.8-T5]: SPARC CNID DB error under Lion AFP [Resolved]
After updating my ReadyNAS NV to RAIDiator 4.1.8-T5 I get the following error when attempting to connect to it via AFP in OSX Lion: "Something wrong with the volume's CNID DB, using temporary CNID DB...
DeltaTee
Jul 28, 2011Aspirant
yoh-dah wrote: Sorry for the late reply. The AFP service in 4.1.8-T5 updates the CNIB DB on first access, and during that access, writes are disabled on the share. If you have a ton of files in that share, it may take awhile to update the DB. Once the update process is complete, you should have full read/write access to the share.
I can just try waiting then (I don't think I had done that one yet). I would assume that disabling/re-enabling the afp on the volume resets the clock. How long is quite a while? Hours? Minutes? Days? Weeks? Will I need to reconnect the share when it is finished, or will it automatically show up read-write? Is there a way that I can check on the ReadyNAS to see the progress (I have ssh enabled).
