DeltaTee
Jul 22, 2011Aspirant
[4.1.8-T5]: SPARC CNID DB error under Lion AFP [Resolved]
After updating my ReadyNAS NV to RAIDiator 4.1.8-T5 I get the following error when attempting to connect to it via AFP in OSX Lion: "Something wrong with the volume's CNID DB, using temporary CNID DB...
sphardy1
Jul 28, 2011Apprentice
DeltaTee wrote: Will I need to reconnect the share when it is finished, or will it automatically show up read-write?
While I cannot be 100% certain - that would be advisable. In the past, any changes made to the AFP service have tended to require the client to disconnect & reconnect to detect those changes, so the cautious approach would be to assume the same requirement for this update. It could also serve as an indication that the update is complete (ie you should not get the error on reconnection if the update is done)
