redpola
Sep 19, 2017Aspirant
4.2.31 on my Ultra 6 has killed my NAS? Drive is read only and frontview hangs.
So I logged into my Ultra 6 and noticed there was a firmware upgrade available from May 2017! Since I get at least two emails from my NAS every day I assume it should have emailed me about this, but ...
Sep 19, 2017Guru - Experienced User
Clearly the file system has corruption, you also need to confirm the disk health.
What do you see in disk_smart.log (reallocated, current pending sectors, offline uncorrectable, etc)? Have you gotten any email alerts related to disk health?
redpola wrote: Does anyone have any suggestions beyond "Backup your 12GB data, install OS6 and start again"?
OS-6 would be up to you. You hopefully realize that your data is at risk, so you should be backing up what you can.
redpola
All fine. The filesystem has no corruption.
I need to get to the bottom of this before I go for OS 6. I'd rather my device worked the same as it did before the OS upgrade. Is it possible to downgrade?
- StephenBSep 19, 2017Guru - Experienced User
The changes in 4.2.31 were mainly security patches - nothing that would cause disk corruption. So I don't think this is upgrade related (despite the timing). You can certainly downgrade if you want to.
- redpolaSep 19, 2017Aspirant
So nothing in the logs... Nothing in SMART...
Hardware? RAM? I might run a memory test and see what that says.
