Kinu
May 08, 2021Aspirant
4.2.31 to io6
please someone give me step by step guide on how to update 4.2.31 to new iO 6 newer i have readynas 2100 v2 Rdiiator 4.2.31 bios 08/23/20211 readynas-NVX-V2 V1.10 if any one can help please
- May 09, 2021
Kinu wrote:HOWEVER I was so excited to do this and did NOT take your advise of backing up my home videos - i thought firmware take effact on the mother board and not impact hard drive
HOW I WAS WRONG
my question is now i revert back to Radar 4.2.31 will get my dat back??????
The working OS on a ReadyNAS has always been on the drives, not in flash. The flash contains a boot loader, the boot menu options, and a clean version of the OS for installation onto the drives. OS6 uses a different OS partition size and volume format, so the NAS must factory default with OS6. Thus, the drives were completely reformatted and re-sync'ed as BTRFS instead of the EXT format used by OS 4.2.x, and with different sized partitions. It is highly unlikely there is any way you can get anything back from those drives. But you can test ReclaiMe for free, so it's worth a try.
Kinu
May 09, 2021Aspirant
Hello Guys
thank you for your support
it worked beautyfully and upgrraed to lastes version of OS
HOW I WAS WRONG
i am currently conpenplating using ReclaimMe data recovery app -
is there any orhter easre way
i admit i am stupid and not listing to you all out there
any suggestion would be aprriciated
Sandshark
May 09, 2021Sensei
HOW I WAS WRONG
