wsneed
Dec 06, 2018Aspirant
4200 v1 will not enter boot mode for OS reinstall
I bought a used Readynas 4200 v1 in order to reuse the 2tb drives that I upgraded from in my other readynas systems.
It didn't have a flash drive in it so I followed the USB recovery steps to creat...
Sandshark
Dec 06, 2018Sensei
The older NASes are particular about the USB drives you use for recovery. So try some others if you have them. The older, the better.
But, if somebody was using it without the internal flash, they may have been running another OS on it, such as FreeNAS. If they were, and updating the motherboard BIOS was part of what they did, you may be out of luck. Just for the sake of testing whether a generic SuperMicro board was a potential replacement for the Netgear OEM one, I found that the OS would not run, even moving over a genuine internal USB drive. I assume that's because it checks the BIOS (so there are no home-grown ReadyNASes).
My experiment was on a 4200V2, but I suspect the same would be true of the 4200V1 and 3200.
wsneed
Dec 07, 2018Aspirant
I found a flash drive that works now and I can see that it boots up to the ready screen through the VGA.
However new the problem is that it refuses to get an IP from my network. I think the onboard network ports are bad.
I'll try a add-on network card and see what happens.
- StephenBDec 08, 2018Guru - Experienced User
First try RAIDar and see if it detects it on the network. https://kb.netgear.com/20684/ReadyNAS-Downloads
- SandsharkDec 08, 2018Sensei
Booting up to "READY" is not enough, if I recall correctly. I think it should get to the point you can log in. I don't run OS4.2.x on my 4200V2 any longer and also don't have a monitor connected to it. But I know runing a virtual machine ends at the login prompt.
- wsneedDec 08, 2018Aspirant
Started with Raidar, then swapped NICs and cables. Finaly checked routers DHCP and found nothing was being assigned.
- Jul 15, 2018Retired_Member
