whc
Dec 09, 2016Aspirant
4K streaming from Readynas 316 possible?
Happy Netgear user now for several years, have no complains at all. Though 4K streaming to my 4K tv over WIFI AC using Kodi or VLC (Android TV) is just lagging as hell, tried new router, did not ...
mdgm-ntgr
Dec 09, 2016NETGEAR Employee Retired
How far is your router from your TV? Are there things in between such as thick walls?
The RN626X would be the model to go with if you want real time 4k transcoding.
CPU performance does improve with new CPU generations but not at the rate it used to.
You can create optimised versions of your 4k video using Plex and that doesn't need to be done in real time. It will take a lot longer on slower CPUs compared with faster ones.
whc
mdgm wrote:How far is your router from your TV? Are there things in between such as thick walls?
Thank you for the fast reply.
My router is about 3 meter away from the TV, the router and TV can see each other without any walls in the way, so there should not be a problem in that front, and the router should have enough bandwidth, though not sure about the TV how fast it is connected to the router.
The RN626X seems to be a beautiful device, I cannot not justify the price, I mean it costs about half what I paid for my car in 2014 with hard drives here in Denmark, and i'm a personal user, only really myself is using the NAS server, so really only need the power for transcoding video files to my TV.
Yes for PLEX i agree, the format could be improved to match the hardware better for transcoding. But so far I know, Kodi and VLC does not transcode, connected to the NAS with SMB (not DLNA or PLEX), and still just lagging as hell. Only short test 4K HDR videoes from Sony. Maybe it is the extra bandwith HDR needs to run smooth? Have not tried any "only" 4K contend, will try that once my NAS is finished installing the new drives.
- StephenBDec 10, 2016Guru - Experienced User
The RN316 isn't the performance bottleneck - 4K content is in the 3-10 MB/sec range (24-80 mbits per second). You have ~8x more throughput then that.
If you can connect the TV with ethernet, that might help - the TV Wifi client might be the bottleneck. You might also try different players - VLC might not be using hardware acceleration.
Generally speaking, it is cheaper to upgrade the player than it is to upgrade the NAS.
- JBDragon1Dec 19, 2016Virtuoso
The 316 is going to be to slow to do any transcoding. My 516 wasn't fast enough either until I upgraded the CPU and RAM and bascially turned it into a 716. You either need a real computer to handle the transcoding or have the video file in a format that it can be directly played on your TV. The NAS is fast enough for direct playback. If it's a 4K TV, it'll Upconvert 1080P content and so you don't need the NAS to transcode. If it's 4K content you're trying to play on a 1080P TV, then it needs to transcode, or you can to convert it over. If it's 4K content to be played on a 4K TV, it should be direct streaming and the NAS shouldn't have any problem with that.
I don't know what you're using to watch the 4K content with? What are you streaming the 4K content to, a App built into a SmartTV? If your TV is in line of site of your Wifi router, why not plug in a ethernet cable between them and give that a try and see if the problem goes away. That's one way to rule out being a Wifi issue. Just because you're close doesn't mean there's no Wifi issues. It's one reason why I wired up my house with Gigabit Etherent. Anything with a Ethernet port on it, I plug in. I only use Wifi for things that move from place to place. Smartphones, tablets, etc. 2.4Ghz Wifi can be over staturated where you live. I fyou can switch to 5Ghz, that may be better, but not everything canuse that fequancy which is why if you can use it, you should use it.
- BaJohnJan 21, 2017Virtuoso
Using Ethernet between TV and ReadyNAS is obviously a good way to prove WiFi is not the critical factor.
However if that is difficult, install Netgear Genie and check the transfer rates between the various components.
That will give an idea of the max rate available, but more than that it will enable you to check for consistency.
i.e. you may only have a problem when your Smart washing machine is in use, or your wirless phone, all
of which can utilise the airwaves.
I have significant WiFi problems where I live and a quick check when things are 'slow' often shows 10 or more
items on my particular WiFi channel.
Hope that helps.
- StephenBJan 21, 2017Guru - Experienced User
Most downloaded H.264 1080p files require about 8-10 mbits. Full BluRay HD has a max bitrate of about 54 mbits.
Netflix UltraHD uses about 18 mbits (certainly no more than 25 megabits). Full BluRay UltraHD has a max bitrate of 100 mbits.
An RN316 can deliver about 800 mbits with large data transfers, so it can easily handle these loads. I think most 802.11n or 802.11ac 5G networks can handle a 25 mbit sustained rate, especially if you use a tri-band router. On the other hand, 100 mbits will be a challenging sustained load for most wifi setups.
So if you really want full BluRay ultra-hd streaming you should plan on a gigabit ethernet connection between the RN316 and the player. But if Netflix quality is sufficient, the RN316 and a good 5G WiFi connection should be enough.
