whc
Dec 09, 2016Aspirant
4K streaming from Readynas 316 possible?
Happy Netgear user now for several years, have no complains at all. Though 4K streaming to my 4K tv over WIFI AC using Kodi or VLC (Android TV) is just lagging as hell, tried new router, did not ...
whc
mdgm wrote:How far is your router from your TV? Are there things in between such as thick walls?
The RN626X would be the model to go with if you want real time 4k transcoding.
CPU performance does improve with new CPU generations but not at the rate it used to.
You can create optimised versions of your 4k video using Plex and that doesn't need to be done in real time. It will take a lot longer on slower CPUs compared with faster ones.
Thank you for the fast reply.
My router is about 3 meter away from the TV, the router and TV can see each other without any walls in the way, so there should not be a problem in that front, and the router should have enough bandwidth, though not sure about the TV how fast it is connected to the router.
The RN626X seems to be a beautiful device, I cannot not justify the price, I mean it costs about half what I paid for my car in 2014 with hard drives here in Denmark, and i'm a personal user, only really myself is using the NAS server, so really only need the power for transcoding video files to my TV.
Yes for PLEX i agree, the format could be improved to match the hardware better for transcoding. But so far I know, Kodi and VLC does not transcode, connected to the NAS with SMB (not DLNA or PLEX), and still just lagging as hell. Only short test 4K HDR videoes from Sony. Maybe it is the extra bandwith HDR needs to run smooth? Have not tried any "only" 4K contend, will try that once my NAS is finished installing the new drives.
Dec 10, 2016Guru - Experienced User
The RN316 isn't the performance bottleneck - 4K content is in the 3-10 MB/sec range (24-80 mbits per second). You have ~8x more throughput then that.
If you can connect the TV with ethernet, that might help - the TV Wifi client might be the bottleneck. You might also try different players - VLC might not be using hardware acceleration.
Generally speaking, it is cheaper to upgrade the player than it is to upgrade the NAS.
