KillerBob
May 05, 2016Aspirant
6.5 RC on Pioneer Pro?
I have been runnning 6.x on my Pioneer Pro for a long time, and the only problem I have is that ReadyCLOUD does not work (it did earlier on, but one of the FW upgrades broke it). I also have 6.4.2 on...
- May 06, 2016
Your system is now showing the correct serial number. You should be able to enable ReadyCLOUD now.
mdgm-ntgr
May 05, 2016NETGEAR Employee Retired
Is your serial number showing in the UI for the Pro the MAC address of eth0 or a 13-digit NETGEAR serial?
If it is the MAC address, is there a label on the back of the unit showing a 13-digit NETGEAR serial number?
- KillerBobMay 06, 2016Aspirant
That is indeed the problem; the serial number on the back is idential to the MAC address of eth0...
- mdgm-ntgrMay 06, 2016NETGEAR Employee Retired
So there's no label with a 13-digit serial? Must be one of a batch of extremely old units then.
There are two labels on the back. The big one reads the MAC address of etho, and the smaller one, reads a 13-digt number. I have PMet a picture to Skywalker and opened up the NAS for Secure Diagnostics Mode. When I look in the logs, in the boot_info.log, the serial listed is the 12-digit MAC address:)
/Bo
