KillerBob
May 05, 2016Aspirant
6.5 RC on Pioneer Pro?
I have been runnning 6.x on my Pioneer Pro for a long time, and the only problem I have is that ReadyCLOUD does not work (it did earlier on, but one of the FW upgrades broke it). I also have 6.4.2 on...
- May 06, 2016
Your system is now showing the correct serial number. You should be able to enable ReadyCLOUD now.
mdgm-ntgr
May 06, 2016NETGEAR Employee Retired
The 13-digit number (will be alphanumeric) is the Serial Number. There was a batch of very old units that mistakenly went out without the serial number programmed in. ReadyCLOUD requires a 13-digit NETGEAR serial number.
mdgm-ntgr
- KillerBobMay 06, 2016Aspirant
All is well in ReadyCLOUD-land:)
- KillerBobMay 07, 2016Aspirant
In all the huff getting ReadyCLOUD to work on my Pro Pioneer, one of the original questions were lost;
So when I read that NetGear is delivering 6.5 just about now, I get a bit exited. So my question is; has anyone tried installing the RC2 FW on a legacy ReadyNAS? Will it work?
- mdgm-ntgrMay 07, 2016NETGEAR Employee Retired
It would work, but the RC firmware does use the beta ReadyCLOUD server so you would need to use the beta ReadyCLOUD accounts, webpage and apps.
