PaulSijben
Dec 05, 2016Aspirant
6.6.0 hotfix removed
In earlier discussions a hotfix was linked fixing the webdav/http access to the NAS. Alas since end of october the web design people from Netgear have deviced to reorder the Readynas information...
- Dec 06, 2016
ah, my problem turned out to be more complex. Postfix was broken and hence newaliases looped indefinitely. reinstalling postfix also did not work. Turned out the root-cause was a wrong ownership of /etc/aliases. After fixing that (chown root:root /etc/aliases) postfix was happily installed as were the rest of the updates.
Paul
mdgm-ntgr
Dec 05, 2016NETGEAR Employee Retired
This is an update that the system should automatically install within a week. In fact there's a newer version of the hotfix now with other fixes as well that would be installed.
Alternatively you could update to 6.6.1 beta.
PaulSijben
thank you. Is there a way I can trigger that hotfix to be installed?
Because if I click on "Check for updates" it comes back with the statement that the software is already up to date.
- mdgm-ntgrDec 05, 2016NETGEAR Employee Retired
You could reboot the NAS. This should force it to be installed within minutes afterwards if it hasn't already been.
- PaulSijbenDec 06, 2016Aspirant
Paul
