vandermerwe
Oct 09, 2016Master
6.6.0 UPS alerts not sent
Had a power supply failure prior to the daily boot up at 08:00. Looking at the logs it appears that a controlled shutdown took place about 2 minutes after the initial startup. The UPS powers other ...
- Jan 04, 2017
Btw ReadyNAS OS 6.6.1 is now available!
In the unlikely event you still have problems on 6.6.1 please start a new thread.
evan2
Oct 09, 2016NETGEAR Expert
Hi Vandermerve,
Could you please tell me which model UPS you are using?
- vandermerweOct 10, 2016Master
The UPS is an APC Smart-UPS 1500I.
There are no emails sent around the time of the power related shutdown according to the log files.
I would expect to be notified about a prolonged power cut leading to a shutdown, this is far more important than knowing that the unit is on or off UPS power, events which do seem to trigger email alerts.
- CigarSurgeonOct 10, 2016Aspirant
Using an APC Smart-UPS RS 1500 and my UPS status is yellow with a UPS_RAWSTATUS_WAIT message.
- AmidalaNov 03, 2016NETGEAR Employee Retired
Hi CigarSurgeon:
Does the UPS status eventually go back to an expected value? Can be used normally now?
-Amidala
