vandermerwe
Oct 09, 2016Master
6.6.0 UPS alerts not sent
Had a power supply failure prior to the daily boot up at 08:00. Looking at the logs it appears that a controlled shutdown took place about 2 minutes after the initial startup. The UPS powers other ...
- Jan 04, 2017
Btw ReadyNAS OS 6.6.1 is now available!
In the unlikely event you still have problems on 6.6.1 please start a new thread.
vandermerwe
Oct 10, 2016Master
The UPS is an APC Smart-UPS 1500I.
There are no emails sent around the time of the power related shutdown according to the log files.
I would expect to be notified about a prolonged power cut leading to a shutdown, this is far more important than knowing that the unit is on or off UPS power, events which do seem to trigger email alerts.
CigarSurgeon
Oct 10, 2016Aspirant
Using an APC Smart-UPS RS 1500 and my UPS status is yellow with a UPS_RAWSTATUS_WAIT message.
- AmidalaNov 03, 2016NETGEAR Employee Retired
Hi CigarSurgeon:
Does the UPS status eventually go back to an expected value? Can be used normally now?
-Amidala
