vandermerwe
Oct 09, 2016Master
6.6.0 UPS alerts not sent
Had a power supply failure prior to the daily boot up at 08:00. Looking at the logs it appears that a controlled shutdown took place about 2 minutes after the initial startup. The UPS powers other ...
- Jan 04, 2017
Btw ReadyNAS OS 6.6.1 is now available!
In the unlikely event you still have problems on 6.6.1 please start a new thread.
vandermerwe
Oct 10, 2016Master
Not exactly. I don't need an alert that the UPS is charging. The alert needs to be about a shutdown if the UPS power reaches the threshold set. This did not happen even though the shutdown was a graceful shutdown when the readynas discovered UPS power was low.
- evan2Oct 10, 2016NETGEAR Expert
I just checked 6.5.1, there is a log entry when it changes to battery power,
and there is a log entry if the UPS power reaches the threshold set.
The issue only happens on 6.6.0, I will file bug to RD.
Thanks for your report.
Following is log on 6.5.1:
- dabanh_freakOct 15, 2016Tutor
I also have this problem.
UPS Warning in Status page
Under Power I have UPS_RAWPOWER_WAIT
Main problem looks like under Performance, I see this:
- hausOct 19, 2016Aspirant
Edit: After hitting "refresh" a few times on the various frontview System pages my UPS section under "Power" now shows green and "On line power". Very strange.
I am also seeing a yellow warning "UPS_RAWSTATUS_WAIT" under "Power" with a Cyberpower CP850PFCLCD UPS system (attached via USB) since upgrading to 6.6.0. I haven't created any power events yet to test notifications or shutdown, but I always had a green status icon under "Power" before the upgrade (I was on 6.5.1).
Under "Performance" right now I have a green icon next to the UPS with "100%".
When I first checked Frontview this morning under "Overview" I had a yellow icon next to "Status" with the same UPS warning as the "Power" tab, but after unplugging the USB cable from the UPS and plugging it back in that icon switched to green and now says "Healthy".
I do not know what UPS_RAWSTATUS_WAIT means exactly, but this is a new message since upgrading to 6.6.0.
