vandermerwe
Oct 09, 2016Master
6.6.0 UPS alerts not sent
Had a power supply failure prior to the daily boot up at 08:00. Looking at the logs it appears that a controlled shutdown took place about 2 minutes after the initial startup. The UPS powers other ...
- Jan 04, 2017
Btw ReadyNAS OS 6.6.1 is now available!
In the unlikely event you still have problems on 6.6.1 please start a new thread.
vandermerwe
Oct 10, 2016Master
Not exactly. I don't need an alert that the UPS is charging. The alert needs to be about a shutdown if the UPS power reaches the threshold set. This did not happen even though the shutdown was a graceful shutdown when the readynas discovered UPS power was low.
evan2
Oct 10, 2016NETGEAR Expert
I just checked 6.5.1, there is a log entry when it changes to battery power,
and there is a log entry if the UPS power reaches the threshold set.
The issue only happens on 6.6.0, I will file bug to RD.
Thanks for your report.
Following is log on 6.5.1:
