vandermerwe
Oct 09, 2016Master
6.6.0 UPS alerts not sent
Had a power supply failure prior to the daily boot up at 08:00. Looking at the logs it appears that a controlled shutdown took place about 2 minutes after the initial startup. The UPS powers other ...
- Jan 04, 2017
Btw ReadyNAS OS 6.6.1 is now available!
In the unlikely event you still have problems on 6.6.1 please start a new thread.
ShoGinn
Oct 20, 2016Tutor
Except it doesn't ewok.
The data is stale which means the communication with the ups is affected.
haus
Oct 20, 2016Aspirant
Thank you. This was my thought too; though I haven't yet tested mine to failure (UPS battery depletion), when I unplugged the UPS from the wall, the ReadyNAS made no indication at all of any power issue, which it has done on the prior firmware. It certainly appears that the ReadyNAS simply has no communication with the UPS and therefore wouldn't shut itself down safely at any point.
I'll give it a shot later on and let the UPS run down fully to find out for sure. My data is backed up anyway.
