vandermerwe
Oct 09, 2016Master
6.6.0 UPS alerts not sent
Had a power supply failure prior to the daily boot up at 08:00. Looking at the logs it appears that a controlled shutdown took place about 2 minutes after the initial startup. The UPS powers other ...
- Jan 04, 2017
Btw ReadyNAS OS 6.6.1 is now available!
In the unlikely event you still have problems on 6.6.1 please start a new thread.
ShoGinn
Oct 20, 2016Tutor
Except it doesn't ewok.
The data is stale which means the communication with the ups is affected.
ewok
Oct 20, 2016NETGEAR Expert
You're right. I took a closer look and saw that UPS health updates are tied to the event mechanism. We'll have a fix available in 6.6.1, possibly sooner.
- JBDragon1Oct 29, 2016Virtuoso
I'm having the same problem myself. I just replaced the battery like 3 months ago. It's a APC 500 Pro I belieave. It's been Yellow for a while. I've been thinking something was wrong with the UPS again. I just went into the settings for it, clicked on Apply and it changed to Green. It's been yellow for a while now. So, clearly a bug.
