vandermerwe
Oct 09, 2016Master
6.6.0 UPS alerts not sent
Had a power supply failure prior to the daily boot up at 08:00. Looking at the logs it appears that a controlled shutdown took place about 2 minutes after the initial startup. The UPS powers other ...
- Jan 04, 2017
Btw ReadyNAS OS 6.6.1 is now available!
In the unlikely event you still have problems on 6.6.1 please start a new thread.
Michael_Oz
Nov 12, 2016Luminary
I'm getting this too.
Since 6.6.0 update yesterday.
RN316
UPS - Cyber Power Value 1200E
Also a old RN NV+ using the UPS and monitoring RN316 for UPS status via network.
First symptom was alert emails from NV+ (nothing from 316):
UPS Communication error. followed eventually by Communication with UPS OK.
Checking the NV+ shows:
| UPS 1 | Remote Error, Battery charge: 0%, 0 minutes | Out of Spec |
(note it was not shutting down after the above)
I looked at the UPS display, all seemed OK.
Then later
| UPS 1 | Remote CPS Value1200E, Battery charge: 100%, 21 minutes | OK |
I then looked at the 316:
316 was showing yellow & UPS_RAWSTATUS_WAIT, constantly. Nothing in the frontview logs.
(this could be a red herring)
System/Power/UPS/Settings/Shutdoen_threshold was Auto.
When changed to 40%, the status went green 'On line power' - for a while...
but the yellow UPSRAW... was back later. So I don't know if changing the threshold matters.
Examination of the NV+ emails/logs show:
Comms OK,
followed, ~10s to a few minutes later with Comms Error.
Then ~ 90 minutes later repeats.
| Severity | Date | Message |
| Sun Nov 13 11:46:29 EST 2016 | Communication with UPS OK. | |
| Sun Nov 13 11:46:25 EST 2016 | UPS Communication error. | |
| Sun Nov 13 11:13:51 EST 2016 | Communication with UPS OK. | |
| Sun Nov 13 11:03:42 EST 2016 | UPS Communication error. | |
| Sun Nov 13 10:59:41 EST 2016 | Communication with UPS OK. | |
| Sun Nov 13 08:13:03 EST 2016 | UPS Communication error. | |
| Sun Nov 13 08:12:58 EST 2016 | Communication with UPS OK. | |
| Sun Nov 13 06:40:42 EST 2016 | UPS Communication error. | |
| Sun Nov 13 06:40:31 EST 2016 | Communication with UPS OK. | |
| Sun Nov 13 03:36:08 EST 2016 | UPS Communication error. | |
| Sun Nov 13 03:36:03 EST 2016 | Communication with UPS OK. | |
| Sun Nov 13 02:03:47 EST 2016 | UPS Communication error. | |
| Sun Nov 13 02:03:32 EST 2016 | Communication with UPS OK. | |
| Sun Nov 13 00:31:16 EST 2016 | UPS Communication error. |
So it seems to be in the Comms OK for the last 30 minutes...(I chaned the settings again and it generated the 11:46 errors above)
Probably a red herring, as I changed it back and got another pair of errors...lately the OK follows the error; I'm wondering if the time shown in the email/logs may be inacurate?
Anyway, I'm 1/2 way thru a 7TB backup, so can't test a simulated power failure ATM.
Will do a test after it finishes.
Michael_Oz
System log, yesterday until this morning this is typical:
Nov 13 08:43:25 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 08:43:30 ME-NAS-316A upsd[26513]: Send ping to UPS [UPS] failed: Resource temporarily unavailable
Nov 13 08:43:30 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 08:43:32 ME-NAS-316A upsd[26513]: Connected to UPS [UPS]: usbhid-ups-UPS
Nov 13 08:43:49 ME-NAS-316A upsd[26513]: Data for UPS [UPS] is stale - check driver
Nov 13 08:43:50 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 08:43:55 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 09:14:10 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 09:14:15 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 09:14:20 ME-NAS-316A upsd[26513]: Send ping to UPS [UPS] failed: Resource temporarily unavailable
Nov 13 09:14:20 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 09:14:22 ME-NAS-316A upsd[26513]: Connected to UPS [UPS]: usbhid-ups-UPS
Nov 13 09:14:39 ME-NAS-316A upsd[26513]: Data for UPS [UPS] is stale - check driver
Nov 13 09:14:40 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Data stale
I don't recall what I did at ~9:45 but
Nov 13 09:45:06 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 09:45:10 ME-NAS-316A upsd[26513]: Send ping to UPS [UPS] failed: Resource temporarily unavailable
Nov 13 09:45:11 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Driver not connected
Nov 13 09:45:21 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Server disconnected
Nov 13 09:45:31 ME-NAS-316A upsmon[26516]: Set username on [UPS@localhost] failed: Server disconnected
Nov 13 09:45:36 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Driver not connected
Nov 13 09:45:46 ME-NAS-316A upsmon[26516]: Set username on [UPS@localhost] failed: Server disconnected
Nov 13 09:45:51 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Driver not connected
Nov 13 09:46:01 ME-NAS-316A upsmon[26516]: Set username on [UPS@localhost] failed: Server disconnected
Nov 13 09:46:06 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Driver not connected
until
Nov 13 10:57:38 ME-NAS-316A upsmon[26516]: Poll UPS [UPS@localhost] failed - Driver not connected
Nov 13 10:57:39 ME-NAS-316A upsmon[26516]: Signal 15: exiting
Nov 13 10:57:40 ME-NAS-316A upsd[26513]: Can't connect to UPS [UPS] (usbhid-ups-UPS): Interrupted system call
Nov 13 10:57:40 ME-NAS-316A upsd[26513]: User monuser@::1 logged out from UPS [UPS]
Nov 13 10:57:40 ME-NAS-316A upsd[26513]: write() failed for ::1: Broken pipe
Nov 13 10:57:40 ME-NAS-316A upsd[26513]: Signal 15: exiting
Nov 13 10:57:40 ME-NAS-316A usbhid-ups[26511]: Parse error on sock: Invalid ctx buffer
Nov 13 10:57:40 ME-NAS-316A usbhid-ups[26511]: Signal 15: exiting
Nov 13 10:57:41 ME-NAS-316A usbhid-ups[5158]: Startup successful
Nov 13 10:57:41 ME-NAS-316A upsd[5160]: Startup successful
Nov 13 10:57:41 ME-NAS-316A upsmon[5162]: Startup successful
Nov 13 10:57:41 ME-NAS-316A upsd[5160]: User monuser@::1 logged into UPS [UPS]
Nov 13 10:59:41 ME-NAS-316A upsd[5160]: User monuser@192.168.1.10 logged into UPS [UPS]
Nov 13 11:03:38 ME-NAS-316A upsd[5160]: Data for UPS [UPS] is stale - check driver
Nov 13 11:03:41 ME-NAS-316A upsmon[5163]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 11:03:45 ME-NAS-316A upsd[5160]: User monuser@192.168.1.10 logged out from UPS [UPS]
Nov 13 11:03:46 ME-NAS-316A upsmon[5163]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 11:03:51 ME-NAS-316A upsmon[5163]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 11:03:56 ME-NAS-316A upsmon[5163]: Poll UPS [UPS@localhost] failed - Data stale
then
Nov 13 11:11:56 ME-NAS-316A upsmon[5163]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 11:11:58 ME-NAS-316A upsmon[5163]: Signal 15: exiting
Nov 13 11:11:58 ME-NAS-316A upsd[5160]: User monuser@::1 logged out from UPS [UPS]
Nov 13 11:11:58 ME-NAS-316A upsd[5160]: UPS [UPS] data is no longer stale
Nov 13 11:11:58 ME-NAS-316A usbhid-ups[5158]: Signal 15: exiting
Nov 13 11:11:58 ME-NAS-316A upsd[5160]: Can't connect to UPS [UPS] (usbhid-ups-UPS): No such file or directory
Nov 13 11:11:58 ME-NAS-316A upsd[5160]: mainloop: Interrupted system call
Nov 13 11:11:58 ME-NAS-316A upsd[5160]: Signal 15: exiting
Nov 13 11:11:58 ME-NAS-316A usbhid-ups[6688]: Startup successful
Nov 13 11:11:58 ME-NAS-316A upsd[6690]: Startup successful
Nov 13 11:11:58 ME-NAS-316A upsmon[6692]: Startup successful
Nov 13 11:11:58 ME-NAS-316A upsd[6690]: User monuser@::1 logged into UPS [UPS]
Nov 13 11:13:51 ME-NAS-316A upsd[6690]: User monuser@192.168.1.10 logged into UPS [UPS]
Nov 13 11:46:23 ME-NAS-316A upsmon[6693]: Signal 15: exiting
Nov 13 11:46:23 ME-NAS-316A upsd[6690]: User monuser@::1 logged out from UPS [UPS]
Nov 13 11:46:23 ME-NAS-316A upsd[6690]: mainloop: Interrupted system call
Nov 13 11:46:23 ME-NAS-316A upsd[6690]: Signal 15: exiting
Nov 13 11:46:23 ME-NAS-316A usbhid-ups[6688]: Signal 15: exiting
Nov 13 11:46:24 ME-NAS-316A usbhid-ups[11151]: Startup successful
Nov 13 11:46:24 ME-NAS-316A upsd[11153]: Startup successful
Nov 13 11:46:24 ME-NAS-316A upsmon[11155]: Startup successful
Nov 13 11:46:24 ME-NAS-316A upsd[11153]: User monuser@::1 logged into UPS [UPS]
Nov 13 11:46:30 ME-NAS-316A upsd[11153]: User monuser@192.168.1.10 logged into UPS [UPS]
Nov 13 11:50:15 ME-NAS-316A upsmon[11156]: Signal 15: exiting
Nov 13 11:50:15 ME-NAS-316A upsd[11153]: User monuser@::1 logged out from UPS [UPS]
Nov 13 11:50:15 ME-NAS-316A usbhid-ups[11151]: Signal 15: exiting
Nov 13 11:50:15 ME-NAS-316A upsd[11153]: Can't connect to UPS [UPS] (usbhid-ups-UPS): No such file or directory
Nov 13 11:50:15 ME-NAS-316A upsd[11153]: mainloop: Interrupted system call
Nov 13 11:50:15 ME-NAS-316A upsd[11153]: Signal 15: exiting
Nov 13 11:50:16 ME-NAS-316A usbhid-ups[11986]: Startup successful
Nov 13 11:50:16 ME-NAS-316A upsd[11988]: Startup successful
Nov 13 11:50:16 ME-NAS-316A upsmon[11990]: Startup successful
Nov 13 11:50:16 ME-NAS-316A upsd[11988]: User monuser@::1 logged into UPS [UPS]
Nov 13 11:50:20 ME-NAS-316A upsd[11988]: User monuser@192.168.1.10 logged into UPS [UPS]
Nov 13 12:13:58 ME-NAS-316A upsd[11988]: Data for UPS [UPS] is stale - check driver
Nov 13 12:14:01 ME-NAS-316A upsmon[11991]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 12:14:02 ME-NAS-316A upsd[11988]: User monuser@192.168.1.10 logged out from UPS [UPS]
Nov 13 12:14:06 ME-NAS-316A upsmon[11991]: Poll UPS [UPS@localhost] failed - Data stale
Nov 13 12:14:11 ME-NAS-316A upsmon[11991]: Poll UPS [UPS@localhost] failed - Data stale
I suspect changing the frontview settings restarts the daemon, it works OK for a bit, then has trouble. ??
Lety me know if anyone needs more info.
BTW helpfully ups.log is empty ecxept for "***** UPS *****"
