vandermerwe
Oct 09, 2016Master
6.6.0 UPS alerts not sent
Had a power supply failure prior to the daily boot up at 08:00. Looking at the logs it appears that a controlled shutdown took place about 2 minutes after the initial startup. The UPS powers other ...
- Jan 04, 2017
Btw ReadyNAS OS 6.6.1 is now available!
In the unlikely event you still have problems on 6.6.1 please start a new thread.
ShoGinn
Nov 18, 2016Tutor
So I upgraded to the beta version as well, and it also cycles between okay and failed.
I have a Cyberpower CST135XLU and a RN104.
Logs are as follows:
Fri Nov 18 2016 6:29:23 System: Error communicating with UPS 'UPS' (). Fri Nov 18 2016 6:29:08 System: Communication with UPS 'UPS' () is OK. Fri Nov 18 2016 5:48:47 System: Error communicating with UPS 'UPS' (). Fri Nov 18 2016 5:48:32 System: Communication with UPS 'UPS' () is OK. Fri Nov 18 2016 5:08:07 System: Error communicating with UPS 'UPS' (). Fri Nov 18 2016 5:07:53 System: Communication with UPS 'UPS' () is OK. Fri Nov 18 2016 4:27:32 System: Error communicating with UPS 'UPS' (). Fri Nov 18 2016 4:27:12 System: Communication with UPS 'UPS' () is OK. Fri Nov 18 2016 3:46:57 System: Error communicating with UPS 'UPS' (). Fri Nov 18 2016 3:46:37 System: Communication with UPS 'UPS' () is OK. Fri Nov 18 2016 3:06:21 System: Error communicating with UPS 'UPS' (). Fri Nov 18 2016 3:06:06 System: Communication with UPS 'UPS' () is OK. Fri Nov 18 2016 2:25:46 System: Error communicating with UPS 'UPS' (). Fri Nov 18 2016 2:25:26 System: Communication with UPS 'UPS' () is OK. Fri Nov 18 2016 1:45:00 System: Error communicating with UPS 'UPS' (). Fri Nov 18 2016 1:44:45 System: Communication with UPS 'UPS' () is OK. Fri Nov 18 2016 1:04:25 System: Error communicating with UPS 'UPS' (). Fri Nov 18 2016 1:04:05 System: Communication with UPS 'UPS' () is OK. Fri Nov 18 2016 0:23:40 System: Error communicating with UPS 'UPS' (). Fri Nov 18 2016 0:23:25 System: Communication with UPS 'UPS' () is OK. Thu Nov 17 2016 23:43:05 System: Error communicating with UPS 'UPS' (). Thu Nov 17 2016 23:42:50 System: Communication with UPS 'UPS' () is OK. Thu Nov 17 2016 23:02:29 System: Error communicating with UPS 'UPS' (). Thu Nov 17 2016 23:02:09 System: Communication with UPS 'UPS' () is OK. Thu Nov 17 2016 22:21:49 System: Error communicating with UPS 'UPS' (). Thu Nov 17 2016 22:21:34 System: Communication with UPS 'UPS' () is OK. Thu Nov 17 2016 21:41:09 System: Error communicating with UPS 'UPS' (). Thu Nov 17 2016 21:40:49 System: Communication with UPS 'UPS' () is OK. Thu Nov 17 2016 21:00:19 System: Error communicating with UPS 'UPS' (). Thu Nov 17 2016 21:00:04 System: Communication with UPS 'UPS' () is OK. Thu Nov 17 2016 20:19:38 System: Error communicating with UPS 'UPS' (). Thu Nov 17 2016 20:19:18 System: Communication with UPS 'UPS' () is OK. Thu Nov 17 2016 19:38:43 System: Error communicating with UPS 'UPS' (). Thu Nov 17 2016 19:34:20 System: New USB UPS detected. Manufacturer: CPS, Model: CST135XLU, Serial: CR7EX2003225. Thu Nov 17 2016 19:34:06 System: USB UPS removed. Manufacturer: CPS, Model: CST135XLU, Serial: CR7EX2003225. Thu Nov 17 2016 19:33:34 System: Firmware was upgraded to 6.6.1-T200.
As you can see I removed the UPS and then reconnected it.
So I am back to not being able to use UPS monitoring :(
