vandermerwe
Oct 09, 2016Master
6.6.0 UPS alerts not sent
Had a power supply failure prior to the daily boot up at 08:00. Looking at the logs it appears that a controlled shutdown took place about 2 minutes after the initial startup. The UPS powers other ...
- Jan 04, 2017
Btw ReadyNAS OS 6.6.1 is now available!
In the unlikely event you still have problems on 6.6.1 please start a new thread.
Michael_Oz
Nov 29, 2016Luminary
ewok wrote:Did you receive similar UPS communication error messages with previous versions of the firmware?
Pre 6.6.0 UPS was working normally.
6.6.0 has UPS problems, as documented by me above ~2016-11-14 (System/Power/UPS -> UPS_RAWSTATUS_WAIT)
6.6.1 beta 1, changed but still has a problem, as documented above ~2016-11-18 (System/Power/UPS -> Waiting for status update.)
ReadyNAS does not detect UPS on battery & does not shutdown as it should.
extracts of syslog are in the above posts showing upsc output
@> ewok wrote:
> What is the output of 'upsc UPS'
Welcome to ReadyNASOS 6.6.1-T200 (Beta 1)
root@ME-NAS-316A:~# upsc UPS
Error: Server disconnected
I sent logs as per mdgm-ntgr request 2016-11-19
Note ShoGinn has this issue as posted above, as do bobaloca powellandy1 TOMA1 as posted here (re beta 1)
ewok
Nov 30, 2016NETGEAR Expert
We haven't been able to reproduce the issue here, would you be willing to adjust some UPS server settings manually and see if there is any improvement?
Try reducing the polling frequency by adding "pollinterval = 10" to /etc/nut/ups.conf, then running "systemctl nut-driver restart". Changing UPS settings in the UI may overwrite these settings, so try not to do that.
